Need Installation for labview 2014 or 2018
Hello, I am a student of electronic engineering and if Can you help to share the labview installer or have an idea where I can get it??
(588 Views)
You can download the older version only if you have an active subscription.
If you're academic and your coursework needs a specific LabVIEW version, then your professor or university should be able to share the installer.
Santhosh
Soliton Technologies
(577 Views)
If you are a student, you are now also allowed to use the free community edition.
Quote from here
Students Enrolled in any Level of School Use Cases
Students enrolled at any level of school may use the LabVIEW Community edition and G Web Development Software Community edition on any computer that is owned by the student for any non-commercial, non-industrial purpose.
(560 Views)
I would also note that LabVIEW has a "save for previous" setting in its menu.  If this is just to turn in files for assignments or share files with users on older versions, that would likely work.
As long as you don't use any features released after the edition you want to convert to, it shouldn't cause problems.  The only things that come to mind are the 2 new datatypes "Set" and "Map", and Interfaces for classes.  You're unlikely to need those as a student.
(554 Views)
Community Edition is great for students, but starts at the 2020 version. If scooby102 really needs 2014 or 2018 they will need a license.
(489 Views)
Hi baburege,
@baburege wrote:
Hello, I am a student of electronic engineering ...
Simple solution: ask either your professor or the IT department of your university!
This is where you get the software for your studies...
(477 Views)
