Need Help with Report Generation Toolkit (Excel)
I don't know if I'm just blanking out here while programming or what but I'll explain my issue.
I'm trying to take multiple text data files (.csv) within a folder location and taking specific data information from those to then put into a spreadsheet (i.e. Excel).
My problem is the task of indexing the elements using a smart sorting process. I have a sample number (row header) and a target value (column header) and I want the data that matches those values to be placed in the intersect of headers.
I also would like to have these headers to programmatically add into the spreadsheet table (ie look and insert the header into the table).
Can anyone help me figure this through? It is greatly appreciated anyone willing to give me some pointers.
Message 1 of 12
(3,700 Views)
Basically i need the data to move into something that looks similar to this.
Message 2 of 12
(3,671 Views)
Not sure what this means.
Can you post what these data files look like? I still don't understand what you are wanting.
Message 3 of 12
(3,654 Views)
The .csv file attached is a sample file that I would be using to do my data analysis.
In regards to not understanding my previous statement - I have rows in reference to a specific test object (ie sample) and each of these samples is put through a series of tests (flow rates) which would be my column markers. I would like a specific measured value to be put in place within the line under the corresponding header.
Each file contains 3 elements needed specificly for the table (the sample (row x), the target flow rate (column y), and the actual flow rate (x,y)) Does this help explain a little better nyc?
The kicker is that I would like the rows and columns to be populated automatically from the files. Then I can have something like this
Sample Number Rotator Cavity Connector Cavity Head Height (cm)   350 300 250 200 150 100 60 40 30 20 15 10 7.5 5 2
31 5 5 59.0   340 292 233 183 139 101 61.6 50.5 39.8 27.4 18.9 12.8 8.569 5.16 2.78
32 5 5 55.0   325 276 223 179 135 95 61.4 46.9 37 26 17.8 12 6.596 5.99 2.36
33 5 5 55.0   329 275 222 171 128 95 60.2 47.9 36.3 25.9 18 12.6 8.499 4.57 2.79
34 5 5 55.0   325 273 224 172 127 100 61.3 47 37.5 22.8 18.4 12.6 8.247 4.65 2.36
35 5 5 53.0   318 267 219 164 129 91 59.7 45 34.4 23.7 16.9 11.7 7.196 4.56 2.18
36 5 5 53.0   321 271 218 167 130 91 59.7 45.8 35.6 25 16.9 11.9 7.72 4.49 1.72
37 5 5 53.0   322 268 208 167 128 94 59.7 46.6 35.3 24.6 17 11.9 7.545 4.65 1.61
38 5 5 53.0   255 224 193 156 122 91 59.9 46.8 35.6 25.8 17.7 11.6 7.898 3.56 1.68
39 5 5 55.0   303 259 213 172 130 95 61.1 45.6 37.1 24.9 17.7 11.4 8.029 4.63 2.36
40 5 5 54.0   325 271 219 167 129 93 60.5 44.5 35.6 25.2 17 11.9 7.943 4.65 2.2
Message 4 of 12
(3,649 Views)
You are showing the end result that you want.
I don't see the files that are being used to build the final file.
Message 5 of 12
(3,646 Views)
the .csv file attached below was the file type I'm getting my data from.
Message 6 of 12
(3,640 Views)
Okay.
But I am not seeing which data from that August 27 file ends up where in the result file.
The Sample ID from the August 27 is #1.
Message 7 of 12
(3,638 Views)
The files don't have much to do with the problem I'm having. I have the data elements I want - Sample ID, Expected, and the last value of the 2nd Half Average Column. I just need a way to organize it to the format I need to display it in.
Big picture - take folder of all the .csv files -> For loop of N files -> take out needed data from each file  -> organize in table.
Message 8 of 12
(3,632 Views)
Huh?
I give up.
Message 9 of 12
(3,624 Views)
My .csv file has 3 pieces that correspond to 1 cell on the spreadsheet. (The Sample = Row, The Flow Rate = Column, The last average value = VAL at (row,col))
Does this make any sense to anyone?
Message 10 of 12
(3,619 Views)
