Need Help to convert 8.2 to 8.0
Hi, I need some help to convert version 8.2 files to 8.0 . I am currently doing a project at school using version 8.0.  Can anyone help me to convert the following files inside the zip file to version 8.0 ? Thank you in advance.
(3,530 Views)
Here U go!
But there is no version called version 8.4. Smiley Wink Yourr attachment says so! Smiley Indifferent
- Partha ( CLD until Oct 2027 🙂 )
(3,523 Views)
In LabVIEW 8.0
(3,521 Views)
Dev,
I beat U atleast in this! Smiley HappySmiley Very Happy
(3,519 Views)
Great Going, Partha
Cheers to that! Smiley Happy
(3,509 Views)
hi i have trouble opening some VI files. could someone help out? whenever i click on the vi it will pop out a window saying LabVIEW: VI version is later than the current LabVIEW version. LabVIEW load error code 9: VI version (8.2) is newer than LabVIEW version (8.0). what should i do? isit it backward compatible?
is there any converters where i can download?
(3,171 Views)
You can post the VIs and ask if someone with 8.2 or hihger can do a save as 8.0 or download the evaluation version of 8.6 and do the conversion yourself.
(3,166 Views)
