04-20-2017 02:16 PM
I am having trouble making the rover move. The "Rover Project" that came with the software includes a code that should control the movement of the rover. The Robot Builder's Guide that came with the robotics kit gives instructions to open and run the "Rover RT Main.vi" and the "Rover Host Main.vi" and use the controls on the Host vi to control the movement of the rover. When I click on the direction arrows to make the rover move in any direction, the rover only moves for a split second. After a direction button is pressed, the rover should move in that direction continuously until another button is pressed.
If anyone is familiar with the Pitsco TETRIX Prime robotics rover and can offer any assistance it would be greatly appreciated.
04-22-2017 02:02 PM
I take it that this is a myRIO Project. Have you been able to get other (non-Tetrix) myRIO Projects to work? Are you working "by yourself" or do you have colleagues or fellow students also doing myRIO Projects? Are any of them having successes? Talk to them!
12-02-2019 05:20 AM
Im having the same issue, when i press any direction button the rover just takes a step rotation. I dont know why, should we manipulate the program accordingly?
Does anybody have worked on this ?
