Need Help Implementing Ramp Function for Kikusui Electronic Load PLZ205W in LabVIEW
Hi NLquist,
I am new to LabVIEW and I am still trying to understand the loop structure in LabVIEW. I am able to ramp up to a particular value with a loop but I am finding it difficult to implement ramping down after ramping up and to make it constant for a while. It will be a big help if you could provide an example.
Message 11 of 30
(1,270 Views)
Hi Varghese,
A ramp is defined by
y := slope * time + offset
Simple math, right?
With correct slope/offset values you can implement any kind of ramp: rising (slope>0), falling (slope<0), steady-state (slope=0). All you need to do is defining slope/offset as arrays and calculate one ramp after the other…
Message 12 of 30
(1,262 Views)
@Varghese89 wrote:
Hi NLquist,
you can define the down ramp like this:
Or is it soemthing else that is not working.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 13 of 30
(1,257 Views)
Hi GerdW,
Thank you for your reply. I understand the ramp function but I am facing difficulty in implementing these one after other. I need to wait till the ramp up function is completed to give ramp down function inputs and I want to execute them continuously. I am in my learning phase and sorry for the confusion.
Message 14 of 30
(1,240 Views)
Hi Jay,
As I mentioned earlier, I can't find that Ramp pattern by delta function. It requires additional add-ons. Thank you for your response.
Message 15 of 30
(1,238 Views)
@Varghese89 wrote:
Hi Jay,
Try this
Message 16 of 30
(1,235 Views)
Hi Jay,
Thank you for the support. I have already implemented a ramp function but I need to give values simultaneously. For example, now i have to change the inputs after every iteration. Is it possible to give all the ramp inputs earlier
(like first ramp from 0 - 100, then from 100 - 50, then 50 -0)
Message 17 of 30
(1,205 Views)
Hi Varghese,
Sure, you can define all the ramp parameters at any time you like!
What exactly do you understand by "simultaneously"?
The ramps should be done one after the other or in parallel!?
Message 18 of 30
(1,200 Views)
Hi GerdW,
The ramp should be done one after the other, so there won't be any delay between them. Thanks in advance.
Message 19 of 30
(1,194 Views)
Hi Varghese,
You can create your waveform (or sample array) with all needed data and then start the output loop to iterate over all those samples.
When that waveforms contains samples for more than one ramp then you have fulfilled your requirement…
Message 20 of 30
(1,178 Views)
