Need HELP on l\Launch & Stop exceted VIs
I would like to launch 2 VI's in parallel without getting problem if one of them is stuck, therefore I create my VI, but I have 2 problems (please see my attached VI) :
1. I could not to shut-down those Launch VIs completely after launching them (After Abort VI, they still running in the back ground)
2. Those Vis has one input & one output, with the way I setup ... can I send 2 commands to those 2 VI's & able to read their outputs in the Main VI? Might be through their Global variables?
Thank for any helps Smiley Indifferent
(2,521 Views)
Hi Plit,
You won't be able to abort a VI the way you have coded the top level VI. You also will not be able to close the front panel if you are calling and aborting the VI.
I recommend creating a conditional terminal within your subVIs and setting a shared variable to stop the subVIs. This way the front panel will close automatically.
Sappster
(2,495 Views)
