Need BER Tester?
[url=http://www.gaotek.com/index.php?main_page=product_info&products_id=147]<B>GAO5853 E1 BER (Bit Error Rate) Tester</B>[/url] is a much small and multi-functional handheld E1 line test instrument , specially designed for E1 PCM line access, maintenance, check and acceptance. It provides BER test, alarm analysis, signaling analysis and so on which can be extensively used in R&D, production, installation and maintenance of SDH, PDH, PCM, DATA Protocol Converter. It is a useful tool for faster problem resolution.
<B>GAO5853 E1 BER Tester Basic Functions</B>
* 120ohm and 75ohm line interfaces
* HDB3 and AMI line codes
* Out-of-service framed and unframed testing
- 2Mb/s, N×64Kb/s BER testing
- Frame data and alarm monitoring
- Clock slip measurement
* Frequency and level measurement
* Clock source: Internal, Interface
* Testing pattern: PRBS, Fix Code, 16-BIT User Word
* Error injection: Single and Fixed Rate
* Real-time transmit circuit open/short indication
* Manual and auto-timer measurement
* G.821, G.826, and M.2100 performance analysis
* USB interface; test results uploaded, conserved and printed by TestManagerPro software
<B>Option</B>
* In-service framed and unframed testing
- Hi-Z and through mode testing
- CODE, FAS, CRC4, E-BIT BER testing
- Frame data and timeslot activity monitoring
- CAS and CCS signaling monitoring
<B>GAO5853 E1 BER Tester Main Features</B>
* Handheld design , dapper design and easy-to-use
* High resolution backlit LCD
* Smart navigation mode displays
* Self-check and keyboard testing function
* Extensive error and alarm generation, detection and indication
* Histograms analysis of alarm and error events
* Up to 99 days continuous test performance
* Save/Recall of up to 7 user-defined setups and 10 sets of results
* Up to 8 hours operation from a single battery charge
* Built-in Li rechargeable batteries and smart charger circuit
* Can be charged with automobile cigarette lighter battery adapter
* Upgradeable software via USB interface
* Test results could be output or printed with A4-szie report form by TestManagerPro software
Company:[url=http://www.gaotek.com][b]GAOTEK Inc[/b][/url]
Phone Number:010-416-2920038
Fax:416-2922364
Mail Box:ON M1B 2k4
Street Address:601 Milmer Avenue,3rd Floor Toronto
Web:[url]http://www.GAOtek.com[/url]
(4,509 Views)
We need test Ber of 10G rate of data using in fiber transceiver module testing application.
(4,500 Views)
please email us atsales@GAOTek.com,or call us at416-292-0038 for Sales ext. 601   416-292-0038 for Support ext. 602
(4,490 Views)
You need to read the Terms of Use. And Touch_Sky, your posting is awfully suspicious. I don't think you could ever convince me that you don't work for this company as well.
(4,475 Views)
you can contact the Replyer if you think so .!
(4,470 Views)
Post his email.Smiley Tongue
(4,462 Views)
i means the the compony is Sourcephotonics , you know LUMINENT.
what i interest is if there's a cheaper solution to test ber BER of 10G in fiber test. like using a PCI  card.....
 I'm just a engineer, i can translate the imformation to our leader.
thanks you.
(4,408 Views)
