Native LabVIEW Datagrid?
Does anyone know if NI ever plans to release a native Datagrid control for LabVIEW (like this one http://www.syncfusion.com/products/Grid/windows/default.aspx)?  It would be great if it was truly easy to embedded an enum, boolean, etc. into a datagrid, table, etc. without having to jump through major hurdles like the brilliant guys at LAVA have done.  I understand you can import and work with ActiveX and .NET controls, but I just don't want another run-time or registration nightmare.
Am I missing this control in the current LV8.5.1 version?
Derek
(3,297 Views)
You should make liberal use of the Product Suggestion Center 😄
(3,289 Views)
Thanks for the link - submitted.  Now I only need to wait a year or two!  Smiley Wink
(3,263 Views)
Derek,
What about an array of type-def clusters?  The cluster would define the row data types and row appearance, and the array would define the table's size and appearance.
Would you please re-state the italicized section from your product suggestion, "There is no easy method of embedding enums, booleans, etc. to any current table or list without full-time development on that portion alone".  If you mean that you must modify the type-def cluster to change the table fields available, then I agree.
(3,234 Views)
