11-14-2008 11:12 AM
I have a wire coming out of a series of math functions. The wire had a name prior to going into the math functions, but it became unnamed after exiting.
This is fine, normally, but it plays havoc when I bundle it into a cluster. I can no longer unbundle it by name because it doesn't have one anymore.
Is there a way to name the wire prior to bundling?
I know I could create a 1-in/1-out subVI that would name the wire, but I was hoping for something more elegant.
Solved! Go to Solution.
11-14-2008 11:27 AM - edited 11-14-2008 11:29 AM
Use a bundle by name node? If you know how many elements you're going to have clustered, it's more efficient to use a bundle by name (with an initialization cluster at the beginning of your program to set all the names) because you're only accessing fixed data space.
11-14-2008 11:29 AM - edited 11-14-2008 11:30 AM
When you use a bundle by name function, you create an input wire to the middle terminal of that function. The constant that defines that cluster can have the values named.
