Name elements of a bundle
Hello to all,
I want to display several variables at the same time in a chart. I am using a bundle for that. I would like to give a name to each bundle signal. Is there a way to do it ?
There is a photo attached.
Thanks 🙂
(5,528 Views)
Hi Mahmoud,
that's what BundleByName is for - use it in conjunction with typedefined clusters…
(5,521 Views)
Accepted by topic author Mahmoud63PPC
You can wire a cluster diagram constant of the correct type to the middle of the bundle function , then name the elements accordingly.
Here is a simple example:
Of course to label e.g. the traces of your charts, you can use property nodes or even manual configuration.
(5,512 Views)
The cluster name won't affect the value of the elements (0)?
(5,484 Views)
Is this a statement or a question? What does "elements (0)" even mean?
The Name of the cluster constant (or whatever is wired to the middle) will be the name of the cluster output ("My cluster" here). The Names of the elements of the cluster constant will be the names of the elements ("Count", "Value" here).
(5,476 Views)
Hi Mahmoud,
Which "cluster name" are you talking about?
(The label of the cluster will not affect any values of the elements in the cluster…)
(5,475 Views)
