Name collision error occurs when building executable
hi
I was attempting to build an executable of my project including .m file with mathscript of course  , but a warning showed up while building and here is what it was showing:
A name collision occurred during the build.  VIs were renamed to protect the build.  If any dynamic calls were made to the following VI(s), unexpected behavior may occur:
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\ComplexMatrix\ComplexMatrix.ctl
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\RealMatrix\RealMatrix.ctl
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\RealMatrix\Methods\Numeric.llb\Multiply - RM,RM.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\RealMatrix\Methods\Numeric.llb\Multiply - RM,R.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\ComplexMatrix\Methods\Numeric.llb\Multiply - CM,CM.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\ComplexMatrix\Methods\Numeric.llb\Multiply - CM,C.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\RealMatrix\Methods\Numeric.llb\Add - RM,RM.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\RealMatrix\Methods\Numeric.llb\Subtract - RM,RM.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\RealMatrix\Methods\Comparison.llb\Equal - RM,RM.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\ComplexMatrix\Methods\Numeric.llb\Add - CM,CM.vi
C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Analysis\Matrix\Support\ComplexMatrix\Methods\Numeric.llb\Subtract - CM,CM.vi
what is this all about and how can i avoid this , i tried to pass it away but the .exe seems to be not running like it should be ( i have to get a treated wavfile as an output)
Please help me to resolve this .
thanks.
(3,180 Views)
can anyone help here ?
please i need help
thanks.
(3,151 Views)
Duplicate
You might want to check this link and check if you have conflicts and solve them
Hope it helps.
Regards.
(3,149 Views)
