NXT Terminal SEARCH Times out Immediately
When I click on SCAN either in Lego MINDSTORMS 1.1 or the Labview NXT terminal the scan aborts immediately.  I have tried editing the MINDSTORMS Options.ini file timeout value but that has no effect.  I have a DELL D630 with a DELL wireless 360 bluetooth radio.  I have successfully connected to a Wiimote using the DELL Toshiba stack/drivers, the windows stack drivers, and had some success with the WIDCOMM v4 stack/drivers but the bluetooth configuration does not seem to have any impact on the timeout/abort.  I have uninstalled the NXT terminal and reinstalled it using both the labview distribution and the Lego MINDSTORMS v1.1 software and that has also not solved the problem.  I have the Lego bluetooth dongle on order but I don't think that will solve the timeout problem.  I am having trouble figuring out what the error condition is partly because the NXT terminal labview block diagrams are password protected.  Does anyone have a suggestion as to what I should try or know of any other configuration changes I could make?
Greg
Message 1 of 1
(2,720 Views)
