NXP PCA9530 & NI USB 8451 Examples?
Does anyone have example Labview code addressing the NXP PCA9530 (2-bit I2C-bus LED dimmer) through the NI-USB-8451?
http://www.nxp.com/documents/data_sheet/PCA9530.pdf
Thanks!
(2,788 Views)
Hi Dhubbell,
I could not find any examples specifically for the NXP PCA9530 but here is a great white paper on using the 8451 with I2C communication.
http://www.ni.com/white-paper/5767/en
There are also LabVIEW examples you can find using Example Finder after you install the NI-845X drivers found here:
http://joule.ni.com/nidu/cds/view/p/id/2647/lang/en
DylanC
(2,774 Views)
Thanks DylanC.  I found my problem, the white paper on the Chip was referencing a 8 bit address and I was using a 7 bit address in my code.  It's working fine now.  I used a good old fashion "loop" to find the correct address! Smiley LOL
(2,772 Views)
