02-08-2018 03:28 AM
Hi everyone,
I'm trying to Install NXG 2.0 using the package manager and get an "invalid checksum..." error (attached).
Any similar experiences or proposed solutions?
Thank you
Solved! Go to Solution.
02-08-2018 04:23 AM - edited 02-08-2018 04:25 AM
I would suggest you to check this post (https://forums.ni.com/t5/LabVIEW/LabVIEW-NXG-1-0-installation-error-quot-Check-Internet/td-p/3635121) where i think an error similar to what you are getting has been solved 🙂
It was with version 1.0 but you might aswell try it out with files for 2.0
02-08-2018 12:49 PM
Have you updated to NI Package Manager 17.5? If not you should try updating that first and then try installing LabVIEW NXG.
02-11-2018 03:52 AM
Thanks, it wasn't exactly the same issue, but I did find the answer there - it was a problem with the local network I was connected to.
02-12-2018 01:17 PM
The issues that were being seen were actually a result of an internal error on our end. We pushed a fix late Thursday night that most likely resulted in the error going away.
