NUL String
I have a string combo box.  Is it possible to have the ascii "NUL" (00 in hex) as a selection in the combo box?  I need the combo box to select a list of strings, but I also need the NUL option, since I need the hex number x00 sometimes.
string => hex equivalent
NA => x00
string1 =>hex equivalent
string 2 =>hex equivalent
string 3 =>hex equivalent
(3,575 Views)
I guess the empty string constant is equal to a NUL string.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,565 Views)
Use the normall string NULL, in the event (or after the control) you check if the value equals to NULL, and then you output x00.
This can be easily done in a sub-vi.
Ton
My LabVIEW Ideas
(3,559 Views)
No it's not, an empty string has lenght 0, a string with the value NULL has a length of 1.
However in C, a NULL string is an empty string since they are NULL-terminated.
Ton
My LabVIEW Ideas
(3,556 Views)
