NSV URL formating
I have found that the Get Shared Variable List vi will sometimes return NSV URL that contain single quotes such as
\\.\process\'tank_pressure' and for other processes the single quotes will be missing.  What causes the difference?
(2,558 Views)
Is there a pattern to the context of the variable's name?
I have seen in the past that path's containing spaces will have names in quotes such as: \\. \process\'Shared Variable1'
Is this a function that is impeding your application?
Logan H
(2,530 Views)
