NSV URL format has changed!
In LV2010, it appears that you now have to include the psp prefix
Example:
ni.var.psp://cRIO-HPU1/HPU System Parameters/HPIM.HE_PID_Kc
where before it was acceptable to just have:
Does anyone know where this change was mentioned in the upgrade notes?
(2,833 Views)
Accepted by topic author viScience
It turns out that this was not the case.  I did not properly format my cRIO targets and for some reason this
messed up my LV2010 installation and produced the above mentioned result.
(2,798 Views)
Ok, this is like ping pong.  Too bad we cannot edit our original posts after 10 minutes.
It turns out that for IOV's you do indeed need the psp prefix in the URL string.
If you leave it out, you will always get an error stating that you have the incorrect read/write access
for the NSV Open.
(2,786 Views)
