NOT GATE
I'm currently using a NOT GATE to convert the value of 1 to 0 and vice versa. But my problem is, when the input is 0 instead of changing it to 1, the Not Gate changed it to -1. And when the Input is 1, it changed it to -2. I couldn't figure out what is the problem.
Could someone help me?
(4,868 Views)
The function is supposed to work that way. It will invert each bit. So, b00000000 is inverted to b111111111.
You can do a =0 followed by a Boolean to 0,1.
(4,865 Views)
Hey Tebu,
You could also add 2 to your output, though this will still allow you to pass invalid values into the not gate and get a non 0 or 1 output. If using this method it would be important to ensure your inputs are what you want them to be.
Chris
National Instruments - Tech Support
(4,838 Views)
Accepted by topic author tebu
Just use "subtract" function from numeric palette. Give constant "1" in terminal 'x' & connect your input value (0 or 1) into terminal 'y'. It will give you the invert values.
-Kumar.B
(4,820 Views)
both method, you and the person above you could be used. Thanks mate!
(4,757 Views)
