NIvisaic crashes with "libnipalu.so failed to initialize"
Hi, my object is trying to read an Agilent scope using LabView 2012 on a Scientific Linux 6.7 32-bit machine.
I installed latest VISA (15) and scope driver, but all examples found in
/usr/local/natinst/LabVIEW-2012/instr.lib/Agilent\ 2000\ 3000\ X-Series/Examples/
immediately crash LabView upon loading.
As a first step in finding what the problem could be I tried to run NIvisaic, that fails as indicated.
I ran NIUpdateDrivers as indicated and rebooted, but NIvisaic still does not work, and neither the examples.
I would appreciate any help, and attach the result of running niSystemRepor.
Thanks!
(3,933 Views)
OK, some more information.
1st, I checked that NIvisaic works on another machine, same OS (SL6) but 64-bit, and it does. So the problem is with 32-bitness.
Next, I noticed file nipalk-load.log, made during installation of NIVISA 15:
FATAL: Error inserting nipalk (/lib/modules/2.6.32-573.12.1.el6.i686/kernel/natinst/nipal/nipalk.ko): Kernel does not have module support
GOOGling for this error concerning nipalk (was NIvisaic lying in its teeth denouncing nipalu.so?) I found this page:
https://decibel.ni.com/content/message/23793
seeming to assert that 32-bit machines may work only if they have 4GB, OR if you add mem=4096M to the GRUB boot line
But the page is 4 years old, and my 32-bit machine happens to have exactly 4 GB, so I do not know.
In any case I tried to add the superfluous mem=4096M to the grub line, but then it won't boot at all. SO funny......
Any suggestion? Thanks everybody willing.
(3,905 Views)
Have you installed the 64 bit version or the 32 bit version of drivers?
Is the machine you used where everything works a 64 bit or 32 bit machine?
(3,881 Views)
Hi, thank you for the answer.
The machine where "everything" works (but is not connected to my scope, being the desktop
in my office) is 64 bit.
As for NI-VISA15 being 32- or 64-bits, I do not know: it is the only version for SL6 available on the National site,
so the site does not give me a choice of bitness. The README.txt (in attachment) does not declare
its own bitness either, and I do notk know how to check. I only know that it seems to compile everything.
I also tried NI-VISA14 but it does not compile because of libstdc++ incompatibility: it requires
a version of libstdc PREVIOUS than the one I have
(3,872 Views)
From this KB:
http://digital.ni.com/public.nsf/allkb/20789C3E4A3DCAFB8625708B00693CF9?OpenDocument
"However, in some cases, mem=4096M may allocate 4GBs outside of the addressable range. This is why it is encouraged to use the memmap method as opposed to the mem=XX method. "
Check if with this something changes!
Cheers
(3,863 Views)
OK, the new switch memmap DID make the trick, and I have been able to boot and install everything (thanks Scaiola88!).
The Agilent 3000x-series examples now do load without choking LabView, and so does NIvisaic. Whoopee.....
Problem is, the scope _doesn't_ show up in the VISA sources: neither from a common user process
nor when running as root. And, yes, I did put the bus in write mode for everybody.
On the other side, my _other_ USB interface (to CANbus if you are interested) _does_ show up no problem.
Could the scope USB bus be broken? I don't think so, because it shows up w
Scaiola88 ha scritto:
From this KB:
Cheers
hen running lsusb,
disappearing when I pull the USB cable, and reappearing directly I plug it back.
Could the scope firmware be only minimally supporting USB? Maybe, but in any case
I think the problem is getting now outside this forum: too tricky, and I give up.
Thank you all!
(3,841 Views)
