NIVIP00\vipm-setup.msi
Hi, I encountered problems while installing labview program I need help urgently
(2,880 Views)
Hi Gabrielix,
a few more information about the issue whould be great.
Are you trying to install LabVIEW out of the already installed NI Package Manager or from a downloaded executable?
Is it the offline Installer? Where have you downloaded your Installer?
Have you tried to install out of the already installed NI PAckage Manager?
Best wishes
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(2,844 Views)
I tried but I did not solve the problem
(2,840 Views)
But there should be a different error message than.
And the answer to my other questions?
(2,838 Views)
This issue happens when a higher version of VI Package Manager is already installed which was directly downloaded from https://www.vipm.io/download/. You can avoid this by unchecking JKI VI Package Manager during installation
This issue has been resolved in LabVIEW 2021+ installers and there is no need to uncheck this even if there is a higher version of VIPM is already installed.
(2,828 Views)
