NIMax 20.5 Add Network Device dropdown is not function in Windows 7
The dropdown is not operable to add a network device.  Clicking on it has no affect.  Is there a version of NIMax where this is not an issue with Windows 7?
(1,363 Views)
Accepted by topic author dkocsis
Hello there,
1. This list has the information bout NI-DAQmx and Microsoft Windows Compatibility, and apparently Windows 7 needs version below 15.5.1. I couldn't find a way to downgrade your NI MAX, so you might have to uninstall and reinstall your drivers.
2. You can try checking out  NI Driver Download and select a Windows7 compatible driver to download it.
3. More information about NI MAX can be found here NI Measurement & Automation(MAX) Download.
Hope this helps
Fiona, NI
(1,305 Views)
Hello there,
Hope this helps
Fiona, NI
(1,305 Views)
