NIMAX v20 Import config failed to copy Bug
Attempts to import a nce (NI Configuration Export) file results in a "Failed to copy DriverSession IVI" error.  From that point the import stops and configReport.txt has that canned error 0X800004005.  This problem doesn't occur on a virgin PC, the first import will work, a second import will cause a "Failed to copy error DriverSession IVI" error.  I like to thanks my well knowledge co-worker for finding this solution, thanks Ray.
Reseting the NIMAX configuration will not fix this issue.  To fix you need to manually delete all IVI Logical Names and IVI Driver Sessions
My project uses IVI drivers to setup a virtual mux thus IVI was critical in NIMAX.
Message 1 of 1
(966 Views)
