Greetings,
On a fresh installation of Windows XP, service pack 2, and on a laptop
less than a year old, I just installed LabVIEW with the very late DAQmx
7.5.0f1. The computer was behaving rather sluggishly shortly
thereafter, and NIMAX.exe is apparently hogging the CPU on boot
as evident in task manager. If I open up the Windows services
(services.msc) and set the nidevldu service to manual instead of
automatic, NIMAX.exe no longer starts up, and the computer behaves
normally. This, unfortunately, causes LabVIEW to not start
properly, but it points to the source of the problem. The
nidevldu service is nipalsm.exe, which in turn seems to launch
NIMAX.exe. On a working installation on a different computer, I
notice that NIMAX does not run in the background.
Please note -- if I launch MAX myself, it does not affect the
issue. The problem is caused by MAX as it runs in the background,
started by a service.
I have uninstalled and reinstalled DAQmx, LabVIEW, and device drivers two or three times, with no change to what is occurring.
How can this issue be resolved?
Thanks very much in advance,
Jim
Message Edited by CT_JIM on 10-12-2005 03:10 PM
