NILRT linux kernel iso ARM compile
I tried to compile linux runtime 21.0 kernel iso for flashing sd card for raspberry pi3.
so i use this instructions:
https://github.com/ni/nilrt/tree/nilrt/21.0/sumo
so i do steps:
bitbake packagegroup-ni-coreimagerepo
and have some problems when cross compiling in UBUNTU.
ERROR: qemu-native-2.11.1-r0 do_configure: Function failed: do_configure (log file is located at /home/osboxes/nilrt/build/tmp-glibc/work/x86_64-linux/qemu-native/2.11.1-r0/temp/log.do_configure.64449)
Log data follows:
| DEBUG: Executing shell function autotools_preconfigure
| DEBUG: Shell function autotools_preconfigure finished
| DEBUG: Executing python function autotools_aclocals
| DEBUG: SITE files ['endian-little', 'common-linux', 'common-glibc', 'bit-64', 'x86_64-linux', 'common']
| DEBUG: Python function autotools_aclocals finished
| DEBUG: Executing shell function do_configure
| ERROR: pa check failed
| Make sure to have the pa libs and headers installed.
| WARNING: exit code 1 from a shell command.
have somebody make iso like this?
Message 1 of 1
(4,057 Views)
