NIHSDIO - Property Node Output Number
NISHDIO Property Node allows many options to choose from, in a pull-down menu.  In an example I have a DataWidth that outputs the #4.  Is their a decoder or explanation that explains the output for each option in the pull-down menu?
ie.
DataWidth = 4
DataRate Multiplier = ?
and so on.
Any references to read would be useful as well.  Thanks
Bret
(2,353 Views)
I am including a link below that lists and explains each HSDIO property. You can also find out what each property is used for by enabling the context help in LabVIEW.
https://www.ni.com/docs/en-US/bundle/ni-hsdio-properties/page/hsdiopropref/cnihsdio.html
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/dialog-boxes/context-help-window.html
I hope this helps!
Cameron T
(2,322 Views)
