NIC directories not getting created under ISAPNP
AT-MIO-16X using NI-DAQ5.1 on Win98  (cross posted from the multifunction daq forum)
I am setting up a spare board after one failed in system - the first board reported failed when the Test Resources button was pressed.
A second board was tried in this system, with no success.
When setting a second (similar PC specs) system up (it had been shelved), the referenced directories are not being created during
the installation of NI-DAQ and board. If I install and set the board up as previously configured, matching the address/irq/dma channels,
the resource test reports "Not responding to the first IRQ". (No conflicts with resources reported.)
After reading other postings (searched forums/knowledgebase, etc.), I tried setting only the base address, and the resource test passes.
Unfortunately, when set up in this manner, the AIO and DIO seem to work but the sinewave generator (test resources again) does not -
nor does waveform generation in our application.
(2,458 Views)
Hello James,
In the future please refrain from posting the same question on multiple boards.
Go here for the active thread.
Dan King
(2,437 Views)
