NI9862 Error Out
I have a NI9862 reading data from a database real time. The data gets pulled into a separate VI and gets plotted on a graph. The duration of the test is supposed to last two hours, with the data being taken across that span. However, mid way though the test we would encounter the following error message attached. Once this message pops up, the data will stop being recorded and the NI9862 will appeared (X) out in NI MAX.
(952 Views)
Hi Ploop,
That's not nice.
What's your question?
I guess your program is doing what you have programmed to do. Most probably this is not the same as what you want to do…
(948 Views)
Hi GerdW,
What's the cause of this error and how can I resolve it? I have the same system replicated in a different facility that runs with no problems but when I've deployed the code onto my current PC, I've started seeing this message.
(943 Views)
Accepted by topic author Ploop
Hi Ploop,
It's caused by some problem in your program and you can resolve the problem by debugging your program…
(902 Views)
