NI9472 Digital Output Module on Labview 2022Q3
Hell community,
I am very nee to LabViw and also new to this community.
I have a cRio9047 and a NI9472. The module should be integrated in a safety circuit to open a emergency contact if some limits are reached. Basically a software emergency stop in line with the hardware emergency stop. I added this to my previously set up system.
My whole setup is in LabView2022Q3 32bit and driver 22.5. If I want to test the module in MAX, there are always problems with the software versions.
The module is pretty old and hasn’t been used the last 6-7 years. I assume it needs an update in the driver or I need a downgrade in my LabView-Version. The NI compatibility list say’s Labview 7 or higher.
Where do I find the version of the module and whats wrong with the versions?
Where do I actually see the actual driver on the module?
Thanks a lot for your help!
Gubernator94
Message 1 of 1
(1,245 Views)
