NI1433 trigger camerlink Cam
Hello
What is to do|:  the ni1433 should trigger a camera over the CC1 line. Are there some examples in the web?
I can adjust the camera to external trigger with trigger source CC1, but what VI do i use?
(3,134 Views)
I've never worked with a Frame Grabber, but have done all of my NI Video stuff using USB or Ethernet cameras that used IMAQdx as the Camera Device Driver.  The Frame Grabber appears to use IMAQ (not IMAQdx) -- have you looked to see if there's a function that uses the CC lines, say, allowing you to set (or pulse) one or more of them?  What does MAX say?  Are there settings in MAX that allow you to manually trigger one of these lines?
I looked at the manual for the 1433 -- it mentions these lines, but doesn't show how it interacts with the software.  Are there LabVIEW examples available for this Camera?  Any hints from the Camera Manufacturer?
(3,082 Views)
Accepted by topic author HallmannSVS
Help->Find Examples
There's examples in there for triggering the 1433.
(3,056 Views)
