NI-usb 6212 simultaneous analog signal output
I apologize about that.  Here is the same VI saved for LabVIEW 8.5.
Chris L
Certified LabVIEW Associate Developer
Message 11 of 13
(444 Views)
There is an error like this
Error -201025 occurred at DAQmx Start Task.vi:1
Possible reason(s):
Non-buffered hardware-timed operations are not supported for this device and Channel Type.
Set the Buffer Size to greater than 0, do not configure Sample Clock timing, or set Sample Timing Type to On Demand.
Task Name: _unnamedTask<9>
Message 12 of 13
(438 Views)
I solved the problem. Thank you very much 🙂
Message 13 of 13
(435 Views)
