My NI package manager shows warning to upgrade version. when i try to do this showing error messages. How can i avoid this?
Tell us a bit more about your system. What is the current version of NIPM? (You should see it when you run it -- look at the list of Installed Packages and find NI Package Manager). What version(s) of LabVIEW are installed? What Operating System are you running?
NIPM - 2017 as per i remembered since now i can't able to check this due to error.
Labview - 2017.0 (both 32 and 64 bit)
Windows - Windows 7 professional
From your response, I'm assuming you have only LabVIEW 2017 on your PC. Here's what I would advise (and would expect to work):
I've forgotten the situation with LabVIEW 2017, but I know that if you do this with LabVIEW 2016, you do not get NIPM.
Offline update package installed and problem solved
