NI cDAQ-9185 Watchdog Expiring Even Though Reset Command Sent
I need to implement the Watchdog Feature on a cDAQ-9185.
I'm using the following code to reset the watchdog (which configures correctly - or at least without fault). The watchdog timer is set to 20 seconds for testing. After approx 7 seconds, the below Vi begins executing every 0.1 seconds, however the c-DAQ still times out. The below Vi also reports correctly that the watchdog timer has expired and fails my system.
Here's the code I'm using:
Is there something I am missing? I've also ensured that there is no error on the error wire, but there is a warning (which is a Uninitialised Shared Variable warning, but it shouldn't cause an issue?)
(2,871 Views)
I've updated both the firmware on the cDAQ and the drivers in MAX too, but still experience the same issue
(2,829 Views)
