NI cDAQ-9184 (Ethernet) not detected with Labview 2016
Hello everybody,
I am trying to set up a new installation with Labview 2016 but MAX cannot see any connected rack and adding it manually is not possible for some reason.
I also have another installation with Labview 2014 connected to the same cDAQ-9184 and it works well.
My guess is that something might be missing in the 2016 setting ?
Please see below the two NI MAX repport.
Could anybody give me some clue?
Should I also update the firmware within the cDAQ-9184 ?
(NI-dQAmx 17 was installed afterward and both PC are under Windows 7)
Many thanks in advance
Yann
LabView 2016 NI MAXLabView 2016 NI MAXLabview 2014 NI MAXLabview 2014 NI MAX
(3,184 Views)
Yann65,
I believe you should try the next few things:
  1. Disable any firewall/antivirus you might have in your computer. Reboot after this step, both the computer and the cDAQ.
  2. Run NI-MAX in administrator mode (right click > Run as administrator).
  3. I see you just have "NI-DAQmx Device Driver" under the software of the machine that´s not working for you. You might want to reinstall the DAQmx driver to make sure you get all three elements: "Device Driver, MAX configuration, and ADE Support". More information here: Can't Find Some DAQmx Functionality After Installing NI-DAQmx Drivers
If these steps don't help. You might want to follow this guide for Network cDAQ Troubleshooting Resources.
Let us know your results. All the best,
(3,155 Views)
The NI-DAQmx Device Driver was not propely installed for some reason.
I did it again and the problem is now solved.
Many thanks for your help!
(3,138 Views)
