NI-XNET fundamental operation
I'm using NI-XNET to communicate over a CAN bus. I am working with two CAN devices at two different addresses. I have defined all of the specifics of the CAN project using the XNET Database Editor.
This is what I don't understand: why does my code continue to run after I exit the routine that writes / reads from the bus, and continues to run until I close the labview program? The frame rate is 100mS on both read and write frames, and my bus sniffer (pCAN) continues to see bus traffic at that rate until labview is closed. Is this normal operation?
What am I missing? What am I doing wrong in my code?
Message 1 of 8
(3,057 Views)
Message 2 of 8
(3,047 Views)
Please avoid duplicate posts - https://forums.ni.com/t5/LabVIEW/Using-XNET-CAN-with-LabVIEW/td-p/4234926
Santhosh
Soliton Technologies
Message 3 of 8
(3,049 Views)
It would be helpful if you could post your vi.
Message 4 of 8
(2,956 Views)
Do you need more of my vi than what I already posted? What part would you like to see?
Message 5 of 8
(2,953 Views)
Where your stop command is coming from? Seems like you either have some parallel process still running or you aren't stopping your while loop properly.
Message 6 of 8
(2,946 Views)
You have posted pictures of your code. It is very difficult to debug a picture.
why does my code continue to run...?
You have some kind of queued state machine. You will need to stop both loops to stop your code from running.
Message 7 of 8
(2,941 Views)
We can't see what parts you have, os how can we answer that?
How do you close and stop you XNET sessions?
Message 8 of 8
(2,938 Views)
