NI XNET does not read CAN database frame correctly
As seen in the picture, I have a CAN database file with frames composed of signals. I read this file using the example program- Exploring database with tree found under NI-XNET. Although the program reads all frames, the signals under Huber2 is shuffled and not read according to frame definition as in the db file next to it. This happens wherever I put these 3 signals(SetPoint flow, Pressure and Temperature), they are shuffled. Other frames are read correctly.
I know I could sort it out using start bit for the signals, however I am confused as to why this happens with just these 3 signals.
(3,164 Views)
Hi GoKu,
looks like the signals are sorted alphabetically…
Are you using standard CAN or CAN-FD?
(3,157 Views)
List is alphabetical?
Qestit Systems
Certified-LabVIEW-Developer
(3,154 Views)
I agree, the list in LabVIEW is sorted alphabetically. Obviously SetPoint_Pressure is parsed correctly, starting at bit 64 with a length of 64.
Regards, Jens
Kudos are welcome...
(3,148 Views)
Yeah I'm using CAN FD
It is sorted such that Upper case has precedence over lower case
(3,120 Views)
Hi GoKu,
             I am also working on a similar project with you, but it is not familiar to use xnet to load DBC to parse can data. Can you share the routine with me?
Thank you very much. Best wishes
(3,046 Views)
Hey, You can find the VI in the attachment. You can find more functionality in the example finder
(3,018 Views)
