NI XNET database editor missing custom frame attributes
I am working with the NI-XNET to import a .dbc file and get information from it with the XNET Databse Get DBC Attributes vi (Frame). Besides the standard attributes such as frame name, DLC, ID, comment, the .dbc files I use contains a few custom attributes for example 'category' where a number is assigned to each frame. I can not find those attributes in the XNET Frame node nor in the database editor. Is there a way to include the mentioned informations?
Thank you very much for your support
(1,666 Views)
This question is best to be posted on Automotive and Embedded Networks board
To my knowledge, NI-XNET Database Editor is FIBEX-based and does not populate DBC attributes. You can only use XNET Database Get DBC Attributes VI to access them.
https://tmesystems.net/
(1,631 Views)
Thanks for your reply. I will try on the recommended forum.
(1,594 Views)
