NI-XNET EXAMPLE
CAN BUS examples
I am using NI-XNET examples with USB 8502
I am expecting to send one CAN BUS frame but it sends out a continual string of identical frames.
I removed the While Loop around the XNET Write thinking it would stop but it still gives a long string of frames.
Any one know how to stop the frames after just one
then change the frame length for the next frame.
(3,020 Views)
john@crane wrote:
CAN BUS examples
Hi, john@crane,
I am not sure about other forum users, but I, personally, have never used NI-XNET. Since I haven't installed the NI-XNET driver, that also means I do not have access to the examples.
However, if you were to provide the actual VI that you are working on, then I (or someone else more experienced) could see what exactly you are doing. This would go a long way in getting you the help you need.
Could you please attach your VI(s)?
joeorbob
(2,959 Views)
Here is the example:
It is unchanged from NI.
(2,909 Views)
