NI-VRTS Reference leak while adding on class
Hi all,
I have used the NI VRTS(version 20.0.1) Driver in my class which has 2 encapsulated vis (i.e.,) Open session.vi and Close Session.vi if I call this vis during execution of exe the application stays on the background process in the task manager of windows system. If anyone had faced this kind of issue in NI VRTS driver kindly share the alternative method to resolve this problem.
Adhithyan
(1,131 Views)
Hi all,
This posted issue is narrowed down.
While we use Ni system configuration toolkit and NI VRTS toolkit in individual classes and called in a vi, which is executing the NI system config toolkit vi to get the hardware resource name and then calling VRTS open session where the input(resource name) is given to it. So there in no problem on running as a 'vi'.
The real problem occurs when you built it as exe and execute it. After closing the exe, It is settled in background process of the PC task manager.
Kindly let me know if anyone is faced and solved this issue. REF attached image.
Adhithyan
(1,071 Views)
