NI VISA not seeing LPT1, although LPT1 working with Logic Analzyer Software
I have run the VISA assistant and it does not see the LPT1, but I know this port to be fully working. It also not listed in the IO Config list. How do I get VISA to see the LPT1 so that I may access it from LabVIEW.
(3,076 Views)
Hi Mark
In order to have VISA working you need to instal MAX - Measurement & Automation Explorer I guess. Then you need to run it at least once. Then the system will determine its configuration.
There is some decription in LTR vol 9, num.4
Hope it helps
Pawel
(3,076 Views)
I already have MAX installed. When I right-click on the parallel-serial port option and try to assign LPT1 to ASRL10 it reports that it is already assigned. However, it is still not in my IO Config Avaliable Types list.
(3,076 Views)
Mark:
"VISA assistant" and "IO Config" are the names of Agilent VISA utilities. I do not believe that Agilent VISA supports LPT1. You need to use NI-VISA for that.
Dan Mondrik
Senior Software Engineer, NI-VISA
(3,076 Views)
