03-08-2018 06:26 AM
I am using a temperature sensor which has 25 * 35 pixels and i have programmed it to print the temperature 8 or 16 frames per second. On any serial application it seems to work as expected but when i try to have labview display it it seems to print very slowly.
I have tried to go into device manager and change the baud rate to match my program but it did not help.
I have previously programmed a similar sensor which had 4*16 pixels (temp values) and it worked absolutely fine and i at least did not have this problem.
Attached below is the previous .vi file for the 4*16 pixels sensor which works great and also the .vi for the 23*35 pixels sensor which has the problem of printing the data very slowly ( with a delay).
A screen capture is also included.
Please Advise.
Thank you
Atif
03-08-2018 06:53 AM
Temperature sensor / pixels? I have no idea what kind of sensor you have. Could you state the manufacturer, and the model? Do you have a manual? Does the manual explains what kind of communication protocol you need to use? In your VI you have only a simple VISA Read in a While loop. Often, a communication consists of a request/response pairs (VISA Write / Read) using a properly set termination character. I repeat, you need to show us the manual, otherwise we can only guess what you do wrong...
03-08-2018 07:52 AM - edited 03-08-2018 08:04 AM
Hi Blokk,
It is a Melexis sensor MLX90621 a higher version of it. It uses the i2c protocol.
I have attached the .vi in the question which is working, that i was able to create for the 4*16 pixels (when i mean pixels - it is a temperature map with 4*16 = 64 temperature values which are being printed on the screen - think of it as a small IR camera )
The problem is when i use a similar higher resolution sensor with a greater temperature map/pixels 24*35 instead of 4*16 the data visualized in labview through the visa read is very slow and not as quick.( please see the zip file attached in the question, it consist of a video of what is happening)
Attached below is the video file for the 4*16 sensor - you can see how quickly the data is printed in labview vs the other video file for the 24*32 bit sensor.( please play both the video files and you will know what i am trying to say)
The data is received through the serial port - it is 8 frames per second. for the new and the old sensor.
I have attached the data sheet for the lower resolution sensor but currently cannot post the data sheet for the higher resolution sensor. the are basically same just higher in resolution/ data acquired/ pixels.
Also i have alredy a microcontroller programed for this sensor - i dont need a visa write.
please advise
Atif
03-08-2018 09:13 AM
"Also i have alredy a microcontroller programed for this sensor - i dont need a visa write. "
So you have a microcontroller, which interfaces the I2C sensor to RS232? I think what you should check, how is this microcontroller is configured, and match the settings in your LabVIEW code... I am not really familiar with such configuration, someone else here might give better ideas what to check/change in your setup...
03-08-2018 09:21 AM
It seems your sensor sends the data as text, so i'll assume 8 bytes/values.
25*35*8=7000bytes
115200 bit/sec ~12000 bytes/sec
You'll get 1,5 values/sec, does that seem about right?
In order to get 8/sec, you'll need roughly 25*35*8*8*10 bits/sec = 560kbit/sec
/Y
03-08-2018 02:33 PM - edited 03-08-2018 02:35 PM
Hi Yamaeda,
Yes that sound about right. - is there something i am doing wrong ? or could you guide me through this ?
Atif
