NI USRP driver for labview 2023
I have installed latest version of LABVIEW  2023 and same version for LABVIEW FPGA . Can you please tell me the correct version of USRP driver that can be installed for both latest version of applications
(1,481 Views)
It is not quite clear if NI-USRP 2022Q4 already uses the LabVIEW version independent installer locations. If it does it should work for your setup. If it doesn't you upgraded to quickly to the latest LabVIEW version.
The Readme file states nothing that it would already support that version independent installation location, so I assume you need to move back to LabVIEW 2022Q3 for now.
Rolf Kalbermatter  My Blog
(1,456 Views)
