NI USB-8476 pinout or "getting started" request
I have NI USB-8476 device, but I do not manage to find the starter guide to find the pinout (maybe because its status is obsolete?).
Could you help ?
Thank you in advance,
(1,502 Views)
Accepted by topic author TeraEngineer
Pins 2 and 7 are the typical ones used on most CAN hardware, with CAN Low on pin 2, and CAN High on pin 7.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019YIGSA2&l=en-US
EDIT: Crap this is a LIN device not CAN.  Ground looks like pin 3 or 6, VBat on pin 9, and data for LIN on pin 7. Page 13  Weird that I can't find much for documentation, but I'm pretty sure the pinout didn't change for XNet devices.
Also you may have a hard time using this.  I believe this uses the older "NI-CAN" drivers and API which I don't think has been updated in a while, since XNet drivers and devices have replaced this product line.  The last release of NI CAN was released over 3 years ago.
(1,455 Views)
Hello Hooovahh,
Thank you for your reply. This is what I got at this link.
I have opened another topic here regarding the use of this NI USB-8476 device on my lin BUS. Could you please take a look ?
(1,436 Views)
