NI USB 6008
HELLO THERE
  i m new in labview 8.0 . can anybody tell me how to read and write input voltage from usb 6008.
i got 6008 usb and already configure with max. i got votage of 4.5 voltage battery but  i want to read and write battery votage through daq assistant. how i do that ?
wait for reply
thanks
rajput
(4,150 Views)
This Link should get you started.
This will teach you use DAQ assistant to automatically generate LabVIEW code
any doubts, do ask
(4,122 Views)
Hi... I´m also new in LabView, but I've got version 8.2. I got 6008 usb and already configure with max. I've looked for DAQ assistant but i was not able to find it, because there is no daq assistant, I even looked with the search function.
can you help me?? does someone know what is happening???
Hugo
(3,946 Views)
Hi Hugo,
You also need DAQmx installed to be able to use the DAQ Assistant with any version of LabVIEW.
(3,915 Views)
Hi Kabul... thanks...
the advise worked for me, my DAQmx version didn't work, so i got the 8.5 version, but the link you provided is a little confusing, so i found this other:
http://www.ni.com/support/daq/versions_portable.htm#du
so i hope it could help you as you helped me, and if not, i'm sure it'll be useful for someone reading this message.
Hugo
(3,884 Views)
Hey Hugo,
I am glad you sorted it out. Yea the link you provided is helpful for direct link to drivers.
Have a good day,
(3,866 Views)
 How to read and write input voltage from usb 6008 without using daq assistant and using daqmx? My daq assistant has expired.
(3,318 Views)
