NI Sync IRIG Triggered timestamp: buffer overflow
I am acquiring NI Sync IRIG timestamps and the recording is triggered by a an analog input source. I also increased the timestamp buffer size but it is still giving me a buffer overflow error.
I'll appreciate any help.
(2,807 Views)
Hi @A.Ramirez,
What hardware are you using? Can you elaborate on the buffer overflow you are seeing as in how long before you see the error after running the VI?
Try breaking down your code to find where exactly the error is being thrown using the highlight execution tool. Then either read faster or write slower.
I hope this helps!
(2,732 Views)
