NI PXIe-6363 communicate with remote system using LABVIEW
I am using LabVIEW to communicate with a NI PXIe-6363 analog channels. but got error  below
what would be the correct way to access the DAQmx physical channel?
 with NI max test panel working fine.
Message 1 of 11
(2,478 Views)
Your images are low-resolution, and hard to read the values, please post better images and the original VI.
Santhosh
Soliton Technologies
Message 2 of 11
(2,473 Views)
Message 3 of 11
(2,465 Views)
It appears your channel name is invalid. Use the exact same name as in MAX or browse for channels using the channel control.
Message 4 of 11
(2,441 Views)
I try same as MAX name of channel but still getting error??
below naming tried but not working.
  • PXI1Slot5/ai0
  • pxichassis/PXI1Slot5/ai0
  • NI-PXIe8135-2F144378/pxichassis/PXI1Slot5/ai0
Remote System access to PXI slot need specific naming method?
Message 5 of 11
(2,434 Views)
What about browse? Does that give you anything?
Message 6 of 11
(2,425 Views)
Wait a minute, No, you cannot remote access NI-DAQmx PXI devices.
The NI-DAQmx devices have to be locally available on the computer you run your code.
If you really need remote access, you can look into gRPC-Device https://github.com/ni/grpc-device
Santhosh
Message 7 of 11
(2,419 Views)
Could you please create a task using NI MAX , and use this task in you Application ,
to Configure a Task Using the DAQ Assistant from MAX
Complete the following steps to create a task using the DAQ Assistant in MAX:
1. In MAX, right-click Data Neighborhood and select Create New to open the DAQ Assistant.
2. In the Create New window, select NI-DAQmx Task and click Next.
3. Select Acquire Signals or Generate Signals.
4. Select the I/O type, such as analog input, and the measurement type, such as voltage.
5. Select the physical channel(s) to use and click Next.
6. Name the task and click Finish.
Message 8 of 11
(2,397 Views)
Santosh is right. DAQmx does not support remote access:
https://forums.ni.com/t5/PXI/Remote-access-to-PXI-with-DAQmx/td-p/1014925
Rolf Kalbermatter  My Blog
Message 9 of 11
(2,383 Views)
Thanks for information.  for the ni/gRPC-Device only sporting specific version of....
  • Windows OS (7....10)
  •  NI-DAQmx (19.0.0 to 21.0.0)
Message 10 of 11
(2,367 Views)
