NI PCI-8430 RS232 with DMA
One of the features of the NI’s RS-232 card is “High-speed DMA Interface minimizes CPU overhead”. When programming them with LabVIEW controllers, are there any special VIs to be used/techniques to be followed to activate/maximize the DMA capabilities of this card?  Or just because it’s a card with DMA feature, I am expected to see an instant boost in performance.
Your input will be appreciated,
Santiago
(2,931 Views)
Maybe it was posted at an inconvenient time. Here is another attempt to reach the LV gurus
thanks,
(2,920 Views)
Hey Santiago,
Sorry for the late reply, but to get back to your question, having the RS-232 board with DMA will optimize your system by itself. In LabVIEW you will have to allow access to DMA transfers, this can be done through a property node under General Settings. As for special coding methods, there really isn't anything that you need to follow to a tee, although there are certain practices that may help further optimize your code. All these can be seen in the example programs under Hardware Input and Output->Serial. I hope that this helps you out
Can Wong
(2,905 Views)
