NI-PAL Service Manager has encountered a problem and needs to close
Hello, I am getting this error after a few hours of running a Labview 7.1 program installed on an XP machine. A reboot and start up of the program seems to go as expected but after the error will pop up again after a few hours.The program appears to still run normally and you can interact with the interface. The following information was listed: szAppName:nimxs.exe szAppVersion: 2.1.1.49152 szModName: nismslu.dll szModVer: 1.4.0.49152 offset: 00003eb7 What does this mean and will I have to reinstall Labview or could it be a WinXP problem? Thanks, Mike Cotharin
(2,838 Views)
Could you please tell me if you are using MAX (measurement and automation explorer)? This looks like a data base corruption.
Miguel Fonseca
(2,807 Views)
