NI Modbus Library
@LV_Pro wrote:
Sorry, the error I am getting is "Error 538182 "Modbus Error: Illegal Data Address"....My issue is trying to figure out what the new ones, Micro820, (apparently AB is/has phased out the MicroLogix 800 series) aren't happy with, what a valid address for it might be.
The manufacturer should have provided a "Register Map" that lists the proper address(es) for the values you need to read/write and when reading registers how to scale the integer(s) to the proper numeric value. Without that you are kinda hooped.
=== Engineer Ambiguously ===
Message 11 of 16
(84 Views)
Are there any protections in place to prevent reading some addresses on your new system? Can you read ANY addresses? I'd try writing a program to scan them individually, one at a time, and see when/if it throws an error. Or, like someone else mentioned, get a general Modbus tool to make sure the thing will actually talk to you.
Also, I second the advice to sniff the packets. Use NI IO Trace if you can, or try HHD Device Monitoring Studio (if it's serial).
Message 12 of 16
(68 Views)
As I recall, some devices will let you read any number of registers at once, but some will complain if you try to read more than what is specified as one entry.
IE if there are two floats at registers 20,21,22,23, some devices would let you read all 4 registers at once. But some will throw an error if you try to read more than 2 registers from each location.
Message 13 of 16
(61 Views)
To me, this sounds like a missing configuration on the PLC side. Do you maybe need to map values to modbus registers?
Message 14 of 16
(34 Views)
I don't remember ever running into anything like that, but it is very common to get the illegal data address error when you try to read any address which isn't explicitly supported by the device (so if the documentation tells you there are values only at registers 22 and 23, then trying to include registers 21 or 24 in a read command will result in an error). With the off-by-one error, it becomes easier to run into this issue. That's why I suggested starting with a generic program and just looking at the actual values which can be read (and mainly getting the documentation).
The other thing which exists is that Modbus has a 125 registers per read "limit" (which like other things in Modbus, is somewhat fluid). That said, I doubt this is the issue in this case (and I don't know which error it would return).
___________________
Try to take over the world!
Message 15 of 16
(26 Views)
Should is the keyword here. Some manufacturers want their users to stay with their own tools and hide or obfuscate such information by various means. I would imagine that A-B, aka Rockwell Automation believe that their tools are so superior that anybody trying to use something else must be nuts. They may advertise Modbus capabilities in the marketing literature, but make it harder then necessary to use that since using their integrated programming environment and HMI software is SO MUCH better to use (also for their bottom line of course 😀).
Other manufacturers simply put such functionality behind a license key that you have to purchase separately if you choose to refuse to use their own tools!
Rolf Kalbermatter  My Blog
Message 16 of 16
(18 Views)
