NI-Max font issue
Is there any way to change the font size of the explorer in NI-Max. The font size is way too small compared to the text in the description box. Any ideas?
HP
(3,482 Views)
Hello HP,
this is not what you asked for, but you can change the font size of the description box. Click in it and do a Crtl + Mouse Wheel Scroll to get similar font sizes.
UliB
(3,448 Views)
This fixed it! You have to right click on the "NI Max" desktop application... click "properties", then in the "compatibility" tab click "change high DPI settings"... then check the "override high DPI scaling behavior" box... and select "Application" from the "scaling performed by" dropdown.
Restart NI max and you are good to go!
If you don't have an NI Max desktop shortcut, click on your windows start or search... type "NI max"... right click on it and click on "open file location". You can right click on "NI Max" from the file explorer and select properties... or create a shortcut to the desktop.
You're welcome!
(3,152 Views)
