01-04-2021 03:52 AM
Hi all
Whene I use NI max ,it shows me a warnning message like is shown in the picture below
any help please and thank you
01-04-2021 07:28 AM
could you translate the error message to English please
01-04-2021 10:31 AM
ok
"A problem occurred while updating the parameters of this device.
the operation exceeded the allotted time"
01-04-2021 10:38 AM
I haven't come across this before, a few questions:
- What parameters are you trying to update
- What hardware are you trying to update (I am assuming you are setting parameters on a piece of hardware)
- Is the hardware ethernet, usb or PXI
- What version of MAX do you have
01-05-2021 03:48 AM
I didn't update anything that message appears whene I just open the NI Max , also after I refresh the page it appears a message like it shows in picture below
01-05-2021 10:44 AM
Again, could you translate that second message into English
Personally I don't have many suggestions here, someone else might come along with more info.
I would try repairing MAX using NIPM. This has fixed obscure errors like this for me in the past.
01-05-2021 11:17 AM - edited 01-05-2021 11:23 AM
I've seen this. The MAX database may be corrupted. To fix it, go to Tools>Reset Configuration Data. This rebuilds the instrument database. A restart is required.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QkRSAU&l=en-US
01-07-2021 01:46 AM
Ok , thank Sir your suggestion solve a problem but it caused a new one . After resetting the configuration ; nothing it appear one I try to add a new network peripheral as shown in picture below.
Thank you
01-07-2021 09:38 AM
I'm not sure I understand. When you try to Add Network Device, there is no dropdown selection? If that's the case, you may need to do as Niatross suggested, and repair MAX.
